SailNet Community - View Single Post - Which Laptops Has Survived Life Onboard?
post #24 of Old 03-18-2007
sailingdog
The two laptops I use onboard my boat are a 12" Mac PowerBook, and an ancient Toshiba Tecra 8000, which is at least eight years old. Most of the applications you use on a boat aren't really all that high powered... word processing, e-mail, web surfing, are all easily handled by even fairly old hardware. Some of the newer navigation software requires a bit more muscle.
I've seen a few attempts at corrosion proofing normal laptops, but the heat inside them generally seems to cause some problems for any type of spray-on corrosion inhibitor. These machines run pretty hot inside.
Ideally, I'd like to get a ruggedized one, but can't justify spending that kind of money, when I can get away with this older hardware for now.
sailingdog is offline
