SailNet Community - View Single Post - Balsa core deck rot problem
post #2 of Old 03-18-2007
ollie820
I had a similar problem. This is what I would suggest. Remove as much of the wet core as possible by picking it out. I used a bent coat hanger. Some suggest using a bent finish nail as a drill bit but I did not have good results. Get as much of the core out as possible. I used a hair dryer with a no heat setting and alternated between low heat and air until it was completely dry. I also drilled some small holes around the area from the underside to aid in the drying. After it was dry I taped off the large hole and mixed up some high density epoxy and injected it with a syringe into a small hole until the cavity was full. I had good results.
ollie820 is offline
