SailNet Community - View Single Post - Balsa core deck rot problem
post #3 of Old 03-18-2007
Sabre66
I've used a small section of bent coat hanger (90 deg) chucked in a drill to remove such areas. The trick is to start small and slowly get bigger until you hit solid core, It took 3 different sized "Bits" then I used a shop vac to remove the debris, wiped down as much of the area that I could get to with acetone and filled with slightly thickened epoxy.
The area I worked on was about 4-5" in circumference.
Sabre66 is offline
