SailNet Community - View Single Post - Using Jib and Genoa at the same time to create spinnaker
post #10 of Old 12-22-2013
capt vimes
capt vimes's Avatar
Re: Using Jib and Genoa at the same time to create spinnaker
This sail configuration is called in german passat sail...
It was developed at a time where wind vanes and autopilots where not very common... So you linked the two sheets back to your tiller or wheel and thus creating an effective self steering system...
But you needed to deploy 2 poles which the majority of the boats don't have, let alone all the lines for that...
Google passatsegel and look for images...
Oh and btw:
In this configuration you do not fly a main and thus the boat tends to roll...
With the main up, the center of effort of the sails is to leeward and hence stabilizing the boat... Without the main, the center of effort is at the centerline and then rolling is only to be expected...
capt vimes is offline
The Following User Says Thank You to capt vimes For This Useful Post:
Zac Penn (12-22-2013)
