SailNet Community - View Single Post - Rail/Teak to Deck Joint
post #4 of Old 03-19-2007
sailingdog
Wayne-
While I would normally agree with you regarding leaving a gasket thickness and then going back and tightening down after the sealant cures, IMHO this is generally not advisable with screwed down items, rather than through-bolted items.
If you do this with a through-bolted item, you can have some one hold the bolt in place, and then tighten the nut onto the bolt, below the deck. This will not break the seal between the sealant and the fastener or apply torque to the sealant in the fastener hole.
However, if the fitting is held in place by screws, the only option is to turn the screw, which will inevitably break any sealant's adhesion to the fastener and likely to the fastener hole...leaving small tears that water will happily migrate down. It may also tear the sealant in-between the rail and the deck, again leaving places for water to enter.
Just my $0.02 worth on the idea.
sailingdog is offline
