SailNet Community - View Single Post - Rail/Teak to Deck Joint
post #6 of Old 03-19-2007
Wayne25
Wayne25's Avatar
SD:
I agree if your only seal is around the screw. However, on a larger bedding surface like a teak rail, you water proof the surface being beded, not the screw hole. I would prefer to see lag to thread bolts be installed and eggcorn nuts used inside. That way both the bedding surface and the fastener can be sealed as described. Also with a bolt, a little countersink on the exterior of the hole filled with polyether will create a great seal.
Wayne
Wayne25 is offline
