SailNet Community - View Single Post - Using Jib and Genoa at the same time to create spinnaker
post #14 of Old 12-22-2013
Faster
Re: Using Jib and Genoa at the same time to create spinnaker
Originally Posted by Zac Penn View Post
Thanks that is very helpful. Instead of two poles couldn't you just drop the main, secure it and then swing it out and use it as a pole for one of the sails, then use a whisper pole for the other sail? I didn't look too hard at all of the picture but I didn't see someone doing that yet.
Zac
Your boom wouldn't swing forward enough to be an effective 'pole' for a headsail when running - you could get the wider sheeting angle, but not clew stability.
Using a proper whisker(s) pole will work better..
Faster is offline
