SailNet Community - View Single Post - Chain Stopper or Chain Tensioner?
post #9 of Old 03-19-2007
sailingdog
The chain stopper is designed to take the some of the load off the windlass, but if you were using an all-chain rode, you really should be using a nylon snubber line—as I don't think a chain stopper is capable of dealing with the loads generated by an anchor rode.
However, I think that 20' is a bit short on the snubber line, since it will probably require you to bring it in and then re-locate the chain hook if you need to let out additional scope for any reason.
The chain tensioner is quite nice for holding an anchor in the roller tightly so that it doesn't rattle, but isn't designed to take much of a load. As a safety measure, I would also secure the anchor to the boat using a piece of 1/4" line or so.
The real use of a chain stopper, the top item pictured in the OP, is when you have to haul up an anchor rode and anchor by hand. It allows you to stop, change your grip on the chain and rest a bit, without having the anchor and rode return to the bottom...
sailingdog is offline
