OMC Saildrives
Plk,
My best friend has a 1974 C&C 25 with 1980(approx) 15hp OMC Zephr Saildrive. It is a great little engine if you are mechanically inclined but it is also old. He had a galvanic corrosion problem last fall which holed his lower unit. The lower unit may not be salvageable although the gears are all still working. We both looked far and wide and eventually found an entire saildrive unit from someone who replaced theirs with a an inboard deisel. His cost on the used saildrive was $550 Cdn I believe. This unit included folding SS prop. Between the two engines he will likely have two useable lower units and lots of spare parts. There are virtually no new parts available.
These are a dandy little engine but you should look around for a spare engine for parts. Your other option is to be prepared to convert to outboard on transom in the future.
Essentially the value of a boat with an OMC Saildrive from that era is less than that of a similar boat with an outboard (IMHO).
Regards,
Mike
