tookewl...with a 100 watt solar panel at 12V the physics dictates that in direct sunlight you can get 8.3 AMPS at full output in direct sunlight. You are suggesting that WITHOUT adusting the panels for the angle of the sun that you can get the equivilent of between 10 and 12 hours a day of direct sunlight on the panels (setting aside wiring losses). That is complete BS.
The solar stick may be a good solution for some to get their panels out of the shade and get more output by tending to their angle frequently but I don't recall them claiming to have repealed the Ohms law. First post here...could you have some commercial interest in solar stick?
The owner of "solar stick" says: "Let’s take a look at the Solar Stik power production... It produces about 6 amps per hour "
You wanna explain how you're getting 80-100 AH out of that?? Maybe you live on a different planet that gets 16 hours of direct sunlight a day???
