  #117 (permalink)
Old 03-20-2007
camaraderie's Avatar
camaraderie camaraderie is offline
moderate?
Lelalu...just saw your latest post. You are wrong. Fixed panels still charge even when not in direct line with the sun AND due to losses through the atmosphere at lower angles you cannot triple the average fixed 50 watt panels output even with frequent adjustment. I had FIXED 160watt panels unshaded on my boat and I WOULD expect that with FREQUENT adjustment your 100 watt panels could meet or beat what I got out of those...see I DO think it is nice to be able to adjust....but it isn't anywhere close to triple since theoretical maximum for your panels is well less than double my actual maximums and you will fall well short of theory in actual use.
Stop trying to make outlandish claims based on little or no knowledge of basic electrical principles for an otherwise good product and then I'll shut up about the output issues.
