SailNet Community - View Single Post - Fairing Compounds, what do "you" use?
post #25 of Old 12-25-2013
christian.hess
merit 25 solo "er"
christian.hess's Avatar
Re: Fairing Compounds, what do "you" use?
On the advice of an old boatyard owner, I use talc as a thickener for epoxy to make fairing goop. Balloons makes nice sanding but it stays so runny that it's hard to work overhead or vertically.
Talc/epoxy can be thickened as stiff as you need and it sands better than anything I've ever used. I find there's no need to worry about the talc being hygroscopic as there is so much resin in the mix plus the top coats that any theoretical absorbency isn't a factor.
It's dirt cheap too if you get it from an industrial supplier. I paid $20 for a cement bag of the stuff 10 years ago - I still have lots.
thats what we have been using down here in el salvador...great cheap stuff and is nice to fair....we are using this method outside and to fair the insides of the cabin tops where they meet the deck as they had loose strand oem glass work
Islander 36 no longer for sale...its MINE!
Planning maiden cruise for November-December 2015 to Panama Canal! The planning begins!!!
christian.hess is offline
