SailNet Community - View Single Post - to cut or not to cut. that is the question.
post #3 of Old 12-26-2013
deniseO30
One of None
deniseO30's Avatar
Re: to cut or not to cut. that is the question.
There may be a backing plate already under the old one. Only way to know is to remove it. If there isn't one.. get a alum. bar thick enough for threads (stainless or bronze good too) matched to the new cleat. Loop a string through the holes after dropping it from the holes in the hull.. pull the ends up.. start a screw on one.. cotton string should let the screw start in the threads.. then do the other. It's called "working blind" You could use a single piece of string or line with a 3rd hole in the center sealed after.
Another way would be with really long screws that you can put the threaded backing plate and pull them up through the hull and new cleat, replace one with the proper length.. then the other.. working blind again
My last project!
deniseO30 is offline
