SailNet Community - View Single Post - Balsa core deck rot problem
post #6 of Old 03-20-2007
sailingdog
IIRC balsa is stronger than Airex physically... and end-grain balsa doesn't allow water to migrate along the interior of the core, which can happen with Airex. Also, balsa works better than some of the foams that were used as it doesn't lose strength under high heat, until a much higher temperature than most of the foams.
In one extreme case, on a dark blue boat, I could see the foam-cored deck depress when a 300 lb. crew walked across it after sitting in the sun through the early afternoon.
sailingdog is offline
