SailNet Community - View Single Post - Autopilot for Rack and Pinion Steering
post #6 of Old 03-20-2007 Thread Starter
witzgall
The boat is 47" (custom), but the wheel is not attached to a pedistal, so a wheel pilot would not work - at least not without running it to the cockpit side, which I would not want to do.
The rackand pinion is locaed directly behind the wheel, in a seat enclosure. There is not alot of room in there, but perhaps it could be modified to house a ram.
I guess I was just hoping there was a simple answer that I was missing...
Chris
I am guessing that this boat has a wheel...so yes... you should be able to install an above deck wheel autopilot as a minimum...
The rack and pinion setup still probably has a rudder steering quadrant.... so an under-deck auto pilot should also be possible.
It would help to say what boat you had, to get recommendations on what autopilots are suitable for a boat of that size and displacement.
witzgall is offline
