SailNet Community - View Single Post - Use of conduit to tidy up cables
post #7 of Old 12-27-2013
poopdeckpappy
poopdeckpappy's Avatar
Re: Use of conduit to tidy up cables
Originally Posted by mad_machine View Post
the downside is it is now a lot harder to run new wires or replace old ones.. it can also hide corrosion from view.
What you can do is leave a couple pull strings in the conduit with small steel washers tied to the end. You can either tuck the string in the ends of the conduit Then retrive as needed with a small telescoping magnet or cut a small slit in each end of conduit to secure string until needed.
And avoid using wire with connnectors ( if possible ) inside the conduit, if you can, make a new run
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
