SailNet Community - View Single Post - Use of conduit to tidy up cables
post #8 of Old 12-28-2013 Thread Starter
MarkSF
Re: Use of conduit to tidy up cables
Originally Posted by jimgo View Post
You mention NMEA and RF wires. I'd look at separating those. I'd be concerned that the antenna might cause cross-talk with the NMEA-compliant wires. Maybe I'm just being over-cautious, but especially when you're transmitting (which probably isn't that often), you may experience some issues.
Good idea, and thankfully I achieved it by accident! NMEA and radio antenna never run together, by pure luck.
Here's the finished result. I wish I could do something better with the NMEA 2000. Simnet is such a better system, much neater to wire. (and I have a Simnet network plugged into the NMEA 2000 one, works perfectly)
Now I just have to figure out if having the Xantrex charger chassis grounded to the engine heat exchanger (yes, you read correctly) is a good thing!
MarkSF is offline
