SailNet Community - View Single Post - Use of conduit to tidy up cables
post #9 of Old 12-28-2013
boatpoker
Dirt Free
boatpoker's Avatar
Re: Use of conduit to tidy up cables
Originally Posted by MarkSF View Post
Good idea, and thankfully I achieved it by accident! NMEA and radio antenna never run together, by pure luck.
Here's the finished result. I wish I could do something better with the NMEA 2000. Simnet is such a better system, much neater to wire. (and I have a Simnet network plugged into the NMEA 2000 one, works perfectly)
Now I just have to figure out if having the Xantrex charger chassis grounded to the engine heat exchanger (yes, you read correctly) is a good thing!
There should be only one DC negative ground on the engine, I'm guessing you have more than one if the heat exchanger is involved.
Is that white thing in the bottom of the photo a battery box ? if so, either it or the charger has to be moved. You cannot mount a charger over batteries.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is online now
