SailNet Community - View Single Post - to cut or not to cut. that is the question.
post #43 of Old 12-28-2013
hellosailor
Re: to cut or not to cut. that is the question.
Ergh, because they're pockets in the cockpit coaming.
"Coaming
From Wikipedia, the free encyclopedia
Coaming (Originally "Coaning",) is any vertical surface on a ship designed to deflect or prevent entry of water. It usually refers to raised section of deck plating around an opening, such as a hatch. Coamings also provide a frame onto which to fit a hatch cover.
The protective metal sheeting or plating protecting against water entry into ventilator shafts in large ships is called a coaming as it suits this purpose.
The term was borrowed by the aviation industry to refer to a low rim around the opening for an unenclosed cockpit.
In addition, it is the vertical surface rising from a hatch, which forestalls the ingress of water and provides a sealing surface for the hatch cover.
Coaming also refers to the raised structure around the cockpit of a kayak."
hellosailor is offline
