SailNet Community - View Single Post - intervention councelor(s) needed...
post #12 of Old 12-28-2013
christian.hess
christian.hess's Avatar
Re: intervention councelor(s) needed...
I owned a herreshof h28 ketch I refit and "restored" and bought in alameda california...it had rot in the stuffing box plank and that was it...it leaked bad....as soon as that was fixed I had one of the most regarded heavy duty and sweet sailing wooden boats of all time
it was double diagonal planked teak on bronze screws and oak frames...one of the strongest combos
I varnised and sanded and did all work myself including recaulking decks, I also resealed the planks when needed etc...I popped a garboard strake when I tightened the rigging too much but I was only 19 at the time
sealed that up and loosey goosey and all was good
it came with a new yanmar inboard and I bought it for $2000, back in 99! ja!
I could sail that boat blindfolded I knew it so well
it was stronger and better built than most glass or steel boats I knew...but it was small, cramped...damp and wet and smelled like and old fart...
yet the decks were always cool...I could climb into the boat from the water with one hand cause it had like 12 inches of freeboard in the stern and it tracked like a train, and hove to like no other
it could also sail downwind with main only in 35 knots do 9 knots like a mack truck and feel safe
everything has its pros and cons though
so take that for what its worth
not all wooden boats are created equal and the same goes for any material boat you chose
avoid hearsay and research the boats you are looking at intensly, Im glad to offer any insight or help if I can
cheers
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
The Following User Says Thank You to christian.hess For This Useful Post:
floatingPoint (12-29-2013)
