SailNet Community - View Single Post - Grease on Propeller for Anti Fouling?
post #42 of Old 12-30-2013
christian.hess
merit 25 solo "er"
christian.hess's Avatar
Re: Grease on Propeller for Anti Fouling?
I think he is reffering to the color of the strut...some sort of coating?
in any case...guys dont polish your props...really....
do you own an ofrshore racing catamaran with 1500hp worth of outboards? abdsolutely no gain doing that
in effect polsihing a prop melts the top layer of most materials
when people say machine polished or buffed down here especially on magesium, aluminum and some forms of stainless what happens is the top layer gets soo hot that it melts...this closes it all up which is good for stuff like chainplates
mirror polished is what they call it
indeed a rough porous blade is the perfect PRIMER for a simple sprayed on antifouling or nothing at all
again if you have a boat with an inboard and power cruise a lot you will notice less growth than when you only use your inboard to enter ports...
on all the boats I have had with inboards I never did anything to the prop...yes the strut or a arm etc but never the shaft or prop
why? cause you can unbalance a prop quite severely by globbing on antifouling....
youd be surprised how much vibration can come with heavy paint not just barnacles....jejeje
cheers
Islander 36 no longer for sale...its MINE!
Planning maiden cruise for November-December 2015 to Panama Canal! The planning begins!!!
christian.hess is offline
