SailNet Community - View Single Post - Galvanic Isolator
post #4 of Old 01-01-2014 Thread Starter
wmjr
Re: Galvanic Isolator
Al (Freedom),
Duh, I never thought of trying to get at it from the outside. Tomorrow I will see if my Pacific Seacraft is set up the same way as your Freedom. Thank You very much.
Al (Coorie Doon),
Yep, looks like same type of thing on the 31 except it is the headliner above a shelf space in the head. I would have to drill out the bungs on the teak trim, remove the screws from the trim and headliner and hope that would let me pull out some kind of shelf inside the space that must contain the shore power inlet. I hate to drill out the bungs and then have to repair and re-varnish but if it works it would make the wiring easy. Sad sad song if it did not give me easy access.
I think I should call Pacific Seacraft. Thumper has always been a tremendous help when I have needed it.
I appreciate the advice. Thanks again,
John
PSC 31 #28
wmjr is offline
