SailNet Community - View Single Post - Symmetric Rudder damage and surprise hardware!
post #9 of Old 01-02-2014 Thread Starter
Reefpoints
Re: Symmetric Rudder damage and surprise hardware!
Hmm, good points to think on - I had assumed it was a an aftermarket repair due to the fact that the "recesses" the bolts are in are roughly and irregularly shaped and a different color than the surrounding material. The basic structure is white while the area over the bolts is a gray-ish blackish color.
So, maybe the gray material is a previous owner's repair over the original hardware.
I suspect you all are right and it might be best to leave the hardware in place - I'll just put a lot of effort into making it very, very clean to ensure a good solid bond.
I was thinking of cutting in deeper to see what, if anything, the hardware is attached to, but now I think I'll skip that seeing as it may just weaken the rudder.
As always, thank you for your help!
I'll post final pictures when the repair is complete.
Reefpoints is online now
