SailNet Community - View Single Post - Galvanic Isolator
post #6 of Old 01-02-2014 Thread Starter
wmjr
Re: Galvanic Isolator
Keith,
There is no room in the panel on the '31 but right next to it there is a wet locker that I only use for storage. I guess I could cut a hole to frame it and then just take the existing ground wire from the panel to the isolator, patch in a couple feet and run a wire from the output of the isolator to where I took the input.
Might be the easiest.
John
PSC 31 #28
wmjr is offline
