SailNet Community - View Single Post - Help choosing the project and the designer/naval architect.
post #5 of Old 01-03-2014
Re: Help choosing the project and the designer/naval architect.
Not much sense in talking about a boat between 28 to 45ft. That is a huge difference. If you have the money for the bigger boat go to a boat between 43 and 45ft, so money is the determinant factor. One a good boat with a good finish, an one off designed expressly by a Na, the difference in price between an Aluminium boat and steel one should not be more than 10% and I am quite sure that almost any NA will recommend aluminium to you.
A good quality custom boat of that size should cost between USD 500 000 and USD 800 000.
If this is inside your budget we can talk about it, if not you can try one of the voyage boats that exist on the market, like the Boreal that Outbound mentioned or the Allures or the OVNI. That should bring the price to a bit less that the lower number but not much, if we are talking about a boat ready to voyage.
If we are talking about a lot less, like 1/3 of that then probably an option would be going to an heavy steel 36ft, the kind Brent Swain design and build. not very pretty or fast but able to do the job.
So, as you sea, budget for a boat is a fundamental piece of information.
