SailNet Community - View Single Post - Voyaging on $500 per month
post #5 of Old 01-03-2014
bljones
bljones's Avatar
Re: Voyaging on $500 per month
You can let your kitty control your cruise, or your cruise control your kitty. I like the idea of low-budget cruising, going small and going now, living the low-wake life, and I like the fact that you are willing to follow the adventure with little in your pocket. But, let's not overstate the virtue here and risk getting reverse-elitist. Logically, if you set to sea with X number of dollars and, as you imply, will work as necessary to supplement your budget, then aren't you simply pointing out that you CAN'T cruise on the budget you set? if you could, you wouldn't be commenting on the ease of finding work.
I like the dinghy you bought, but I'm curious- if your budget is tight, why spend $600 on a dinghy when you could build a D4 for half of that? Money not spend is money you don't have to work to earn.
It's 5 o'clock somewhere:
bljones is offline
The Following User Says Thank You to bljones For This Useful Post:
randyrhines (01-10-2014)
