SailNet Community - View Single Post - Using a temporary mooring
post #17 of Old 03-26-2007
Valiente
Valiente's Avatar
Originally Posted by sailortjk1
Just be careful if you are the mooring for an extended period of time or if conditions deteriorate. When on the mooring for extended periods it is best to have a special mooring rig made. It consists of a swivel shackle and usually two mooring lines. The lines have thimbles spliced into the eyes, which are permanently spliced onto the shackle. The shackle is than attached to the mooring ball with a large clevis pin.
Like I said, short periods of time are ok, but any length of time or heavy weather and the simple line through the ball will chafe and break. Overnight in calm conditions, youíll be just fine.
I have two 3/4" three-strand lines with thimble and chain with moused shackles. I run them through chocks to well-backed deck cleats and I use chafe gear at the chocks. I need to get a swivel shackle, as a few days of rotating lows and hence around the compass winds can rapidly make this a mess.
Valiente is offline
