Clanking Cables Inside My Mast
Everytime I''m in a quiet anchorage, the slightest movement sets off an obnoxious din of coax cable and wires clanking inside the mast of my Cal 29. I''ve heard that riveting a pvc tube inside the mast to run the cable through is the prevalent fix. This is a difficult procedure with lots of holes drilled into the mast (one for the rivet and one to grab the tube every few feet). Has anyone tried pulling the noisy cables out (on retrieval lines) and at every couple of feet, firmly attaching heavy zip-ties cut off to 12" tails that will act as a spring to hold the cable bundle against the inside of the mast? Another quickie solution has been said to be attaching blocks of foam either to the cable bundle or on a separate line to limit the space for the cables to swing around insdide the mast. I''m worried the quickie solutions may not work well, but I''m not thrilled with the hole drilling & riveting either. Does anyone know how well these work or know of other solutions?
