SailNet Community - View Single Post - Embedded Chain plate maint/replacement
post #136 of Old 01-06-2014
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Embedded Chain plate maint/replacement
Wrap your new chainplates in packing tape and have them ready to go. Slather the thickened epoxy on the appropriate hull surface and slip the chains into place - they will custom form the exact shape of mounting base they want. Once the epoxy kicks you can remove the chains, peel off the tape and mount them permanently.
Another option is to wrap them in tape and mount them lightly in their final position - then trowel thickened epoxy in behind them. After it kicks and you remove the chains you can go back over the formed "landing" and touch up any voids with more thickened epoxy.
SloopJonB is offline
