SailNet Community - View Single Post - Clogged Marine Head
post #1 of Old 03-29-2007 Thread Starter
mathislaw1
Clogged Marine Head
Just recently purchased a used 35 foot sailboat. When sailing her home, I noticed that I could not get water to pump out of the head. I have no problem pumping water in. And yes, I switched the lever to dry when I tryed pumping it out. I believe that it is clogged as tiny bits of toilet paper have starting floating back into the bowl. The holding tank is completely empty and there is no Y-valve that separates the holding tank from the overboard discharge.
The question is: "Can I use draino or a snake on a marine head?" Are there any other suggestions besides having to take the thing apart?
Thanks for you help.
PS. The plumbing is not PVC pipe but marine grade plubing hose.
mathislaw1 is offline
