SailNet Community - View Single Post - Clogged Marine Head
post #7 of Old 03-29-2007
TrueBlue
Seņor Member
TrueBlue's Avatar
I suggest you be very careful if using a snake - particularly extending the metal snake beyond what you can see. Depending upon the make of your head, there is a high risk of damaging rubber components which make up the valves and gaskets.
Try using a manual bilge pump to empty as much liquid from the bowl as possible and begin to disassemble the manual pump - working your way down to the discharge hose and finally, if the source of clogging isn't yet found, to the rubber joker valve at the base of the toilet.
True Blue . . .
sold the Nauticat
TrueBlue is offline
