SailNet Community - View Single Post - In the category of the only stupid question is one not asked?
post #8 of Old 03-30-2007
sailingdog
Originally Posted by camaraderie
Mike...since Conchy Joe did not make it clear in his post...you should be aware that he runs an equipment review website and that solar stick owner is one of his advertisers and friends. Nothing against the product....interest like that should be disclosed so you know where it is coming from.
As far as the claims go...the solar stick on a mooring left unattended will perform exactly like any other 100 watt fixed solar panel attached to an Mptt charge controller. Only when you are on the boat to adjust the panels can you expect increased output. The solar stick may make good sense for you from a mounting or ergonomics standpoint but you must be aboard to expect increased output compared to a fixed 100w panel.
Even if you are aboard and adjusting the panels, his claims of nearly 80 Amp-hours a day are very implausible. The numbers just don't add up as several of us have pointed out in the related solar-panel thread.
sailingdog is offline
