SailNet Community - View Single Post - Diesel engine help
post #5 of Old 03-30-2007
EscapadeCaliber40LRC
leave blank
I would guess (never been there myself) that you should start with an oil change, check all hose lines leading to engine and tank for bad or missing connections, change out the filters if you have any, and drain the Racal water traps if these are in place, bleed all introduced air out of gas lines afterwards, check the starting battery for power and wiring to starter for good electrical continuity, check condition of belts, check condition of impeller and replace if questionable, check condition of throughhull and intake of cooling seawater including filter making sure it is clean and flowing to impeller, examine exhaust path as best you can for rust and corrosion, manually crank it over, check fuel in tanks and in filters for proper color, try to sample fuel from bottom of tanks, then turn the key and see what happens. Somewhere in the midst of this checking activity, I would recommend that you also locate a near by source of good diesel mechanic skills and engage they in some practical "what if" questioning. If all these check out chances are you will have compression, and power to the starter motor. So if the starter turns it over, and the fuel is present,with air properly bled out of fuel lines, it should fire up. Contaminated fuel is probably your main risk. If it starts to run, immediately check for sea water flow out the exhaust pipe (should be there) and examine exhaust smoke if present for color, and check for smoothness of engine running, watch oil pressure gauge for proper reading, shut down promply if anything seems suspicious. You know how to cut the fuel source right ?
EscapadeCaliber40LRC is offline
