SailNet Community - View Single Post - Diesel engine help
post #11 of Old 03-30-2007
BarryL
BarryL's Avatar
turn over by hand, my thoughts
Hello,
I would put a large socket and breaker bar on the crank bolt and try to turn the engine over by hand. This will let you know if the engine is seized or not, water logged or not, etc.
If that works OK I would make sure there is fuel, oil, and coolant. Then I would connect a fresh battery and try to start it.
If it starts and runs, I would turn it off after a few minutes. THEN I would change fluids, filters, impellers, belts, etc.
If it doesn't start I wouldn't spend another penny until I knew why. No point in spending good money if the engine is shot.
If you start off by changing things, and it doesn't run, you have no way of knowing if you did something wrong, or if there is something wrong with the engine.
Case in point. My new to me boat came with an engine that ran great - when I could get it started. Since I knew the engine ran, my diagnosis was much easier. In my case the glow plugs were not getting power because of a bad connection. When I cleaned the contacts the engine became much easier to start.
Then I changed the fuel filters. And the engine would not start. It was because I bled the primary filter and secondary filter, but not the injectors. Since the engine ran before I touched the fuel filters, it had to be something I did.
If I just started changing things, trying to get the engine started would have been much more difficult.
Good luck,
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
