SailNet Community - View Single Post - Vacuum Sealing Gear and Supplies
post #35 of Old 01-11-2014
MikeOReilly
MikeOReilly's Avatar
Re: Vacuum Sealing Gear and Supplies
Originally Posted by vtsailguy View Post
Is it "native" 12V or is the adaptor a transformer?
i.e. can I just stick an adaptor on my my current 110V sealer and end up in the same place? I wonder because going up and down in the voltage makes a big difference:
Gear Review: GPK Car Charger for Apple Macbook ? sailingwithkids.net
Hi vtsailguy, I'm not sure I understand your question. I'm sure you can always run your existing sealer via a DC to AC inverter. Probably not the most efficient way to do it, but I'm sure it would work. The one I bought uses a direct DC power connector (standard 12-volt plug), drawing 6.3 A. It also has an AC connection.
I don't know how it is wired internally. Perhaps that info is available through Foodsaver.
Why go fast, when you can go slow.
MikeOReilly is offline
