SailNet Community - View Single Post - Live Aboard Marinas in Florida
post #3 of Old 04-02-2007
sailingdog
I'd second spending most of your time on the hook. If the boat is properly outfitted, you really won't need much in the way of shore power, water or the other amenities that you get with a marina slip except on the occasional basis.
You can setup a boat to be self-sufficient in terms of electrical power, without requiring that you run the engine or a generator all the time.
You can sail out pass the three-mile limit once a week to empty the holding tank if you have the tank setup properly.
That only leaves food and hygiene requirements. Food is pretty doable, with a weekly or bi-monthly grocery store run, especially if you have a refrigerator on-board. Showering can be done using a solar shower.
Be aware that living aboard is heavily restricted in many parts of Florida, and if you're anywhere near one of those areas, you'll be bullied by the local law enforcement more likely than not.
sailingdog is offline
