SailNet Community - View Single Post - Flushing/testing/preping an old water system on a new old boat
Old 04-02-2007
sailingdog sailingdog is offline
Yup... shock treat the whole fresh water system... then flush it out a few times. Put some vinegar into it after the shock treatment has been flushed to get rid of any nasty residual odors or tastes... and then rinse a couple more times.
Before you shock treat though, you should check the hoses. If they're coated in gunk, it would probably be wise to install new hoses after shock treating the system. No sense in getting the gunk in the new hoses. Most FW systems use a clear hose, and if it is black, or grey with gunk... ditch them. If you're really worried, might be worth replacing the FW faucet fixtures too.
