SailNet Community - View Single Post - Even pros run out of fuel
post #20 of Old 04-02-2007
sailingdog
I've seen fuel systems with valves for the fuel and return lines... and the valves weren't keyed to each other, so you could have the fuel come out of the port side tank and return to the starboard tank. Always created a huge mess if the return tank was full... UGH..
Last system I helped install, we put in a bar that ties the two valve handles to each other... so you can't turn one without turning the other. It can be removed pretty easily so if you have an emergency, you can do it... but it will prevent it from happening on a casual basis.
sailingdog is offline
