Old 03-20-2002
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
temporary jib set-up
Trying to rig a temporary stay in a 30 footer is a lot of work with perhaps not especially rewarding results. Bow cleats are designed for loads essentially parrallel to the deck. Vertical loads will stress the hull/deck joint and the thru bolts on the cleat. You can add a tie rod down to knee but it is a lot of work. Stretch in a spin halyard would result in a pretty powered up sail when you least need it.
Most furlers these days have a luff bolt rope track that would let you drop your big genoa and go to a 100% to 110%, or so, jib using the same track and halyard. I would have the smaller sail cut as a jib rather than a #3 genoa which should give you a wider windspeed range.
