SailNet Community - View Single Post - Best Homes w/Slip in the Chesapeake Bay Area
post #14 of Old 01-15-2014
willyd
美國佬
willyd's Avatar
Re: Best Homes w/Slip in the Chesapeake Bay Area
Originally Posted by jsaronson View Post
It is almost impossible to build or cut trees within 1,000 feet of the Bay. The fine is 5k per tree! In order to reduce run-off, there are strict limits on how much of a lot can be covered with impermeable surfaces. The State wants you to build tall homes with small footprints.
Then there must be some exceptions to the rule or certain officials are more flexible than others, because a number of houses have gone up near us that don't seem to follow these codes. Nearly all the houses that I ave seen go up within a half mile of our beach on lots where an older house was knocked down are tall, but also as long and wide as the lot itself. In one case, two houses were built 3 feet apart and and arm's reach from the neighbors on either side.
1964 Whitby 25
Severna Park, Maryland
willyd is offline
