SailNet Community - View Single Post - Anyone taken a Columbia 28 offshore?
post #8 of Old 01-15-2014
tomperanteau
Crotchety Old Member
tomperanteau's Avatar
Re: Anyone taken a Columbia 28 offshore?
Originally Posted by mrhoneydew View Post
It came with the Atomic 4 in it, but it won't start. I had intended to put a diesel in it... which I have an Atomic 5411 and Hurth transmission that I will rebuild before I swap them. In the meantime I am planning to tinker around with the A4 to see if I can get it running and use it this spring/summer. Then I would have a running engine that I can sell.
I think I am set for main and jib (have roller furling), though I will likely look into getting a used set in case I blow something out. Haven't decided between drifter or spinnaker, but I need something for light wind. Been thinking about an Asymmetrical kit from sailrite. Thanks for the input... it will likely come down to cost, mostly. I need a storm jib that I can hank on over the furler too. Then I need a 30' dinghy to tow behind so I can haul all of this stuff with me!
In re your thoughts on repowering; it you're going offshore, go with a diesel. Gas turns to varnish, but diesel will last a year or two before you need to worry about it.
Capt'n Tom Living Aboard 50/50
S/V Footprints
Youtube
1976 41' Morgan Out Island Sloop. Refitting and redoing her interior for an extended voyage.
tomperanteau is offline
