SailNet Community - View Single Post - How big a holding tank vs. camping
post #25 of Old 01-16-2014
Minnewaska
Re: How big a holding tank vs. camping
It really gets me that humans are the only animal not permitted to relieve themselves on a mountain. There is a right and wrong way to do it, so that others don't have to sleep on the fresh. However, do some believe we don't belong on earth?
Back to holding tanks. While I've done it, I do not think its a good idea to leave urine in the bowl, if you have an electric macerating head. I'm trying to picture the setup, but I'm pretty sure the jocker valve is after the metal macerator, which will corrode in time.
Flushing clear water is the primary key to keeping the head and hoses from smelling. Salt water is fine, if it doesn't lie around long enough for organisms to die, as long as its clear and all waste has been flushed to the holding tank. With a vented loop above the water line, it takes a minimum of 1 gallon per flush to do so. More, for some reason, if you have an electric head.
Jeanneau 54DS
Minnewaska is offline
