Old 12-28-2000
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Moderator
Jeff_H will become famous soon enough
Removing antifouling paint
In as much as bottom paint is quite toxic, you would probably be better off doing it outside. Also it is not a good idea to let the residue soak into the ground. I would use a drop cloth to catch and contain the droppings. If you choose to grind or scrape it off where a high quality repirator. If you use chemical removers make sure to protect your skin. No matter which method you use, with all due respect to Mike, the job will take a lot longer than two hours. Then again the hardest part might be emptying your garage.
Good luck
