SailNet Community - View Single Post - Engine start shuts off chartplotter
post #3 of Old 01-17-2014
eherlihy
Learning the HARD way...
eherlihy's Avatar
Re: Engine start shuts off chartplotter
Engaging the starter is pulling the voltage available to the instrument circuit below what is needed to keep the chartplotter on. I suspect that you may not have a fuse on your battery bank either....
Is this a new symptom, or has this come about suddenly?
Where to start:
Fix the ground to the engine block. I suggest adding a negative bus bar, and connecting everything to that.
Inspect the cables that run to the battery bank for corrosion, both at the connectors, and in the cables themselves.
How healthy are the batteries in the bank? Have you had them load tested? (
eherlihy is offline
The Following User Says Thank You to eherlihy For This Useful Post:
Gladrags1 (01-17-2014)
