SailNet Community - View Single Post - Windlass
Thread: Windlass
post #10 of Old 04-05-2007
sailingdog
Freesail- If you're using a metal backing plate, don't forget to round the corners of it with a fairly large radius, to prevent hard spots against the glass. Also, don't forget to fair in above the backing plate, with a high-density filler thickened epoxy, so that there is no gap between the plate and the underside of the deck. If you use an aluminum plate, don't forget to coat the bolts with lanocote or some other galvanic isolation compound and use a polyethylene washer under the stainless steel washer, to help reduce corrosion problems.
If you go with a wood backing board, use 1/2" marine plywood, and epoxy coat it after drilling all the holes to protect it from water intrusion and rot. Then use at least 1" diameter fender washers on the bolts that go through to the windlass.
sailingdog is offline
