SailNet Community - View Single Post - Thru Hull Fittings
post #2 of Old 03-22-2002
scnicklefritz
Thru Hull Fittings
How many thru hull fittings does the boat have? Wood, glass or steel hull?
I wonder if you could rig a steel bucket with a hose fitting in the bottom of the bucket, force the bucket against the hull using some sort of rubber gasket as a seal and turn the water pressure on and look for leaks from the inside??
scnicklefritz is offline
