SailNet Community - View Single Post - why so long?
Thread: why so long?
post #4 of Old 01-18-2014
christian.hess
christian.hess's Avatar
Re: why so long?
the long tiller is probably cause the po liked it that way...
a lot of racers and dinghy sailors and small keelboaters use tiller extenders(which is better than just a long tiller) as it pivots but the long tiller is because a lot of helmsmen like to sit up forward by the coaming or cabin...it also allows solo sailors for example to be close to the main halyard winch, or sheets etc if lines are led aft for a quick adjustment or douse...etc...
I prefer tiller extenders usually with a foam grip...the best we made on the j24 we raced for example was a very light aluminum tube with a rubber strap cord running through it and into the tiller end...it will pivot in all angles and be flexible
in any case these are my ideas on why you have a long tiller...having said that with you having a helper on board there is no need for such a long one as space will be cut down as you already know
cheers
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
