SailNet Community - View Single Post - Moisture!!!
Thread: Moisture!!!
post #3 of Old 04-08-2007
sailingdog
DLM-
Definitely sounds like water has gotten into the deck.. that's a bad thing. While potting the holes as described by Paul is a good idea... you'll probably have to remove the stanchions and pot the holes for them as well. However, you need to find out whether the core has rotted or is just wet. If it is just wet... you can dry it out by drilling holes to let air in and water out...
Did you get a survey on the boat??? If not, this is a good example of why you get a survey... and if you did, ask your surveyor about it and why he missed it... Wet core is definitely something that should have caused a price adjustment in the purchase price. It can be an expensive repair. However, from your description I would guess that the deck is cored with end-grain balsa and that the damage is fairly limited at the moment. The reason I'm guessing end-grain balsa rather than a foam or marine plywood, is that water tends to migrate more freely when it has been cored with the latter two materials. End-grain balsa tends to keep water confined due to the way it wicks water.
sailingdog is offline
