SailNet Community - View Single Post - Rallies Gone Wrong
post #615 of Old 01-20-2014
smackdaddy
Re: Rallies Gone Wrong
Yeah, keep ignoring the fact that the PERCENTAGE of boats lost in the 2011 NARC Rally was considerably higher... Sorry, but you're better at gymnastics, than math... :-)
Then, there's the matter of the recent fatalities in both the 1500 and NARC within the past 3 years... They own that record.
So, despite your inability to offer ANY EVIDENCE WHATSOEVER that any of these incidents can be attributed to "Inexperience" (the examples I've cited indicate quite the opposite, as a matter of fact), you continue to insist that issue is somehow unique to the SDR...
The stated "Bar to Entry" is no lower for the SDR, than for the 1500... Completion of a "Bluewater Passage" for the former, a "Passage of at least 250 miles" for the latter. If anything, the bar seems set lower for the 1500, to me... Unless you can offer evidence that the organizers of the SDR admitted applicants who did not meet those stated qualifications, you really should cease making this assertion... And, as I've alluded to before, Hank shared an anecdote in an email which casts a wholly different light on how 'strict' the 1500 has been in the past, when it came to acceptance of an entry... Dave/Auspicious was copied the same email, he could confirm...
Also, the NARC does not conduct a 'Safety Inspection', either... But, the SDR "owns" that issue, as well, right? Again, despite your inability to offer ANY EVIDENCE WHATSOEVER that any of the SAR incidents in the SDR were attributable IN ANY WAY to the lack of said inspections, you continue to believe what you want to believe...
Or, are we to suppose that all those OTHER crews far less experienced than the boats I've cited above - who successfully completed their passages - are the ones that are supposed to be indicative of the problems that the SDR has with "Inexperienced" participants in their rally?
Seriously, as one wag commented over on SA, you need to get a bigger shovel... :-)
I can't really keep up with your wild spinning of things across all these different rallies. If you don't like the way they are set up, start a thread on them and critique them. This thread is about the SDR. So, let me keep it very simple.
Among all the rallies under discussion, the SDR is the ONLY rally to my knowledge to have the following combination:
1. A low bar to entry for this kind of trip (a single bluewater passage).
2. No mandatory safety regulations (e.g. - ISAF-based, etc.)
3. No safety inspections.
4. No required level of skipper/crew training, and very limited supplemental training opportunities via the rally itself (e.g. - a single 1-day seminar for a limited number of participants).
5. It's free.
Additionally, the SDR is indisputably the ONLY rally to have the following outcome:
5 SAR cases in 36 hours - resulting in a freakin' Marine Safety Alert from the USCG!!!
http://wow.uscgaux.info/Uploads_wowI...1_and_2_14.pdf
Now, how ever you want to try to justify the above facts against any other rally by picking and choosing line items - or requiring Bigfootesque "causal proof" of specific items that is not yet available for anyone to provide. Knock yourself out. But none of that matters to the issue of this thread and the above facts.
My point is and has always been that the SDR is, without question, the ONLY rally we've been discussing to have the above combination of protocols and failures. And this is undoubtedly a bad combination any way you try to slice it.
With the USCG's making an example of the outcome of the SDR specifically as follows...
In a recent offshore regatta [that would be the SDR, not any other rally you mention above], numerous sailboats experienced steering system and other failures which required assistance and/or rescue by the U. S. Coast Guard when a weather system stalled offshore creating higher than expected sea states and winds. The Coast Guard responded using an array of assets to render assistance.
Offshore sailing requires special knowledge, skills, and abilities. Vessel equipment and components must be thoroughly checked before getting underway and periodically while at sea. The offshore domain’s remoteness adds a negative dynamic to survivability concerns. Preparation is key to minimizing misfortune.
...AND laying out "strong recommendations" that certainly seem to buttress my view (and which are much more in line with the other rallies' protocol), your defense of the SDR status-quo is certainly growing more and more out of touch.
Shovel?
smackdaddy is offline
