SailNet Community - View Single Post - 1977 Hunter 30, Go or No Go?
post #3 of Old 04-08-2007
sailingdog
Hunter had earned a reputation for making shoddy boats for a while...which is probably how they survived when other boat makers went belly up. The Hunter 30 Cherubinis are fairly well respected when many of the others are not...but I don't know whether the boat you are looking at is a Cherubini model.
Many boats are capable of island hopping if you pick your weather window very carefully. However, there are many boats that would be better suited for what you're planning on doing.
If you're planning on single-handing the boat, it might be wise to look at some slightly smaller boats... The Cape Dory 28 comes to mind, as do the Pearson Ariels and Tritons.
Living aboard requires a shift in mindset. Are you sure you're ready to do that? It also, generally, requires getting rid of most of your possessions, since a boat has rather limited stowage.
sailingdog is offline
